Home View Keyboard Shortcut???
EagleBee93
EagleBee93
Is there an option for a keyboard shortcut for:
"right click home button on view cube > set current view as home > fit to view"
I've searched the customization keyboard shortcut menu and haven't been able to find if this is even possible.
Frederick_Law
Right click on empty ribbon area.
EagleBee93
Tried that, it's not doing anything. If I orbit/rotate the part or assembly and then press "H" (which is what i have the shortcut set to) it does nothing... Am I missing something?
Frederick_Law
H doesn't work.  Probably all single character key won't work.
Use Fn or add Alt, Ctrl.
EagleBee93
So it's not letting me change it to shift+H, also I noticed when i click on that alias, at the bottom it says "Note: this command has a reserved shortcut (F6); an alias may be added to this command, but not a customized shortcut" (I'm not really worried about what the shortcut is, I'll just leave it as F6)
With that being said, I can just use F6 to return to home view, BUT this still doesn't solve what my original post was asking...can i set a shortcut to CHANGE the home view? Not just to return to the home view, but to actually set a new one.
It's very cumbersome having to make 3 extra clicks everytime I make a new part and need to set a new home view.
EagleBee93
So it's not letting me change it to shift + H, also I noticed when i click on that alias, at the bottom it says "Note: this command has a reserved shortcut (F6); an alias may be added to this command, but not a customized shortcut" (I'm not really worried about what the shortcut is, I'll just leave it as F6)
It's very cumbersome having to make 3 extra clicks every time I make a new part and need to set a new home view.
Frederick_Law
If you can find the command in the list, yes.
After a quick test, no.  Both are not a command.
