Inventor Forum
Hole View Table
5 REPLIES 5
379 Views, 5 Replies
Hole View Table
Hi, I have a punched part but in the drawing cannot insert a hole view table with the punched features. Can somebody help me out?
Hole View Table
5 REPLIES 5
blair
blair
Hate to be the bearer of bad news but unless the feature is created with the "Hole" command it's the only way to get the Hole Table to work. Even if you create a round cut using the Cut/Extrude command, they won't end up in the Hole Table. You will have to create a Feature Table manually, which really sucks if you change the model parameters. Thought I could trick IV by creating holes before the Punch Feature in the Model Tree and use the locations for the table but IV didn't fall for it.
Delta Tau Chi ΔΤΧ
Delta Tau Chi ΔΤΧ
in reply to: blair
Strange enough that on a older version drawing I could see a hole table with similar punch features and also the IV help side says that the punch iFeatures have to come in a hole view table(the standard coloumn tabel indicates also to punch created table)....
blair
blair
Something must have gotten stripped off, I'm on IV2015
Delta Tau Chi ΔΤΧ
Delta Tau Chi ΔΤΧ
johnsonshiue
johnsonshiue
Hi! The workflow is not as straight forward as it could be. The workflow has not been changed. You need to do the followings.
1) The view must be based on flat pattern, not folded model. You need to recreate the base view in the drawing.
2) Check "Recover Punch Center" option in the Base View dialog.
3) Hole Table -> Hole (View) -> pick a point on the view to place the origin -> pick a place for the table. The table will look empty because Punch centers are not captured by default.
4) Double-click on the table -> Options -> check "Punch centers" in Included Features -> OK.
5) If you always want to include "Punch centers" in the hole table, you can go to Manage -> Styles Editor -> Hole Table -> Options and change the defaults there.
Thanks!
Software Test Engineer
Thanks!
in reply to: johnsonshiue
Thanks John. The mark on punch centres made the whole difference. But why I get not in the table the punch ID tag? How can I bring it on? Can I edit it?
