Hole/Thread Notes
Hole/Thread Notes
Hole/Thread Notes
I am unable to edit a Hole/Thread note after placement.   I was able to do so on this exact same drawing and part yesterday but suddenly it won't give me the edit option.  I can't find a setting that would cause this to stop working.   Only thing I had changed was the default "VIEW PLACEMENT" from 1st to 3rd Person in the Manage Styles section.
Restoring default Inventor options doesn't change it and using a different style standard doesn't seem to work either.   I'm very confused as this happened once before and it spontaneously fixed itself (or I did it in a fugue).
Attached a screen shot showing the "edit" option not even showing up.
CCarreiras
HI!
1. Did you tryed to double click the annotation?
2. Restart your PC.
if it doesnt work, attach here the files.
Inventor version?
CCarreiras
RobJV
My "Edit a Hole Note" is gone as well.  This is the first time i have come across this.  How did you fix yours?
RobJV
Never mind -  I used the extrude command instead of hole on this item which limits individual editing.
