Hole Table XDIM YDIM Edit Text
Message 1 of 8
I have created a hole table with the following columns:
I would like to turn off or delete or edit the text of some (not all) of the XDIM YDIM values in order to denote them as reference dimensions. I do not want to get rid of the hole all together though.
For example, if I wanted to denote the locating dimension of hole A1 the row would ideally look like this:
How would I do something like that?
Thanks.
Replies (7)
Message 2 of 8
mcgyvr
Why use a hole table at all then?
But no there is no option for static text for some of the holes in a hole table..
For whatever reason you want to do this.. I would just not include those in the table..
Message 3 of 8
blair
You could remove the X & Y columns from the Hole Table, You really don't have many options to suppress or hide.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 4 of 8
I only want a few holes to be referenced on the drawing. I have about 70 other holes that I would like in the table. For example, I have 8 A-holes that need to be referenced on the drawing and two other A-holes that can appear in the hole table.
Message 5 of 8
I am hoping to avoid ordinate dimensioning, but that's where I will probably end up if this can't be done. Thank you both for your replies.
Message 6 of 8
brendan.henderson
You can add a Hole Table and select only the holes you want included in the table. The other holes can then be dimensioned by other means.
Brendan Henderson
CAD Manager
New Blog | Old Blog | Google+ | Twitter
Inventor 2016 PDSU Build 236, Release 2016.2.2, Vault Professional 2016 Update 1, Win 7 64 bit
Please use "Accept as Solution" & give "Kudos" if this response helped you.
Message 7 of 8
mikejones
How about an additional Comments column and write 'REFERENCE ONLY' for those holes?
Autodesk Certified Professional
Message 8 of 8
This is the solution that I have settled on for the time being. Thank you all very much for your help.
Alex
