Hole Table Dimension Unit String
mikegreslick6607
mikegreslick6607
When displaying unit strings for the XDIM and YDIM in a Hole Table, the unit string for inches is different depending on the decimal/fraction format of the column.  Below, you see that the unit string for the XDIM is 'in' (the column unit format is Decimal), yet the unit string for the YDIM is ' " ' (the column unit format is Fraction Not Stacked), further the unit string is 'in' for the hole description, and that format is obviously fraction.
Is there any way to display the unit string as 'in' for fraction format?  This seems to be the only place where the unit string for inches is ' " '.  Why?
I don't think that this is a template / styles issues because I believe this is reproducible just like this out of the box. Any ideas?
Inventor Professional 2018.2.3
mcgyvr
Its a bug..
@johnsonshiue ... bug.. squash it please Smiley Wink
johnsonshiue
Hi Guys,
This one does look like a bug to me. The behaviors are not consistent and they should be. It should always be "in" as opposed to double-quote. I will work with the project team to understand it better and see what we can do.
Many thanks!
Software Test Engineer
