Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Hole Feature Fastener Fit Name
mat_hijs
mat_hijs
I'm experimenting with editing the "Clearance.xls" file to create custom clearance holes for fasteners. It seems to work like I expect but I would like to change the names in the dropdown list for Fit (Close, Normal, Loose). I already tried changing the column headers in the Excel file but this doesn't seem to be where Inventor gets the names since they are still unchanged.
Is it possible to edit these names somehow or are they simply hardcoded into Inventor?
If it is possible to do this, would it also be possible to add or remove options?
johnsonshiue
Hi Mathijs,
I could be wrong but I don't think the header can be changed. Even if it was changed on the table, the three options were hard-coded. I don't see a way to customize it in the dialog.
Many thanks!
Software Test Engineer
mat_hijs
That's a clear answer, now I know I shouldn't keep searching. Thanks!
