Hole Command/Call-out with Thread and Chamfer
Is there a way to add threads to a hole in the hole command? Or can you only add a thread feature to a hole separately after the hole is made? More importantly, is there an auto drawing note that will call-out both the hole dimensions and the thread at once? I would like to easily combine the information in the 2 arrows below into one self updating call-out.
Sometimes I also make a hole with the hole command without a chamfer, and then add the chamfer later with a second command. Is there a way to include the chamfer in the hole call-out on the drawing if the chamfer is made in this way?
CGBenner
@Anonymous
Threaded holes are a standard part of the Hole Command dialog.  Chamfer would be an additional machining step, so that is a separate feature.  You can manually edit the Hole note, however, to add the chamfer information... if you choose.
Chris Benner
Ah yes, thank you. I see how that option works now, much appreciated.
