Ho can I prevent users from opening another instance of Inventor
cadadmin
cadadmin
 Is there a command line or registry edit that can be made to prevent users from opening a 2nd instance of Inventor? This is problematic for "some users" who are working on one project and then open a second project and subsequently  (and continuously) do not realize the items they are working on are no longer set by the parameters of the first projects settings.
Tom
Xun.Zhang
Hello Tom,
Try this - Use AHK. Map your Inventor key to the following script (This one is mapped to Windows+Z).
Each time (Windows+Z) to launch Inventor, the instance active state is checking by default to prevent a new instance.
#z::
IfWinExist Inventor
WinActivate
else
Run Inventor://
return
Hope it helps!
Xun
cadadmin
Xun Zhang,
Thank you! I will try that for the users that seem to be having difficulty on a regular basis. While it would be preferable to have a setting in Inventor, or a command line switch, I am up for anything - this should do the job.
Tom
I can't see any situation that would benefit from having 2 instances of Inventor running. So why not build the mutex (that's how this thing is called) right into the program ?
