Highlight edges when using fillet
nathaphon.sulimphumi98KNR
Message 1 of 11
When I use fillet, blue dotted lines normally appear on all edges. Now it is gone, do you know how I can get it back?
Below you can see what I mean with the lines.
Thank you!
Replies (10)
Message 2 of 11
JDMather
Shift Right Click
What is your current selection filter priority?
Message 3 of 11
Hi, @JDMather
Thank you for the response. I checked and it's the same.
See the attachement for the screenshots.
Thank you.
Message 4 of 11
JDMather
The resolution of your images is too poor to be useful.
The usual practice is to use the Windows commands Shift Win S to grab a screen capture and Ctrl v to Paste the screen capture into a Reply.
I think I saw another thread where this highlighting/selection process might be a regression in 2023.1
What version of Inventor are you using?
Can you Attach a sample *.ipt file here?
https://forums.autodesk.com/t5/inventor-forum/inventor-professional-2023-1-update/td-p/11294726
Message 5 of 11
Sorry about the screenshots. Thank you for the tip!
See the attachment for the version + sample without the blue edges.
Thank you!
Message 6 of 11
JDMather
I did not go through your feature history tree carefully - but the first thing that jumps out to me is where is Solid5?
Message 7 of 11
Solid 5 is just some lettering that is suppressed. See attachment.
Thank you.
Message 8 of 11
johnsonshiue
Hi! I think JD is right. This is about prehighlighting. Go to Tools -> App Options -> Colors -> check "Enable Prehighlighting."
Many thanks!
Software Test Engineer
Message 9 of 11
Hi, @johnsonshiue
Thank for the response. Unfortunaly that is not the case, I tried both of them and it dind't change anything.
Please see the attachment for both the files. Thank you!
Message 10 of 11
johnsonshiue
Hi! I am sorry I think I have misunderstood your request. I am back to square one. I don't know what you meant by blue dotted lines in this context.
Many thanks!
Message 11 of 11
Hi, @johnsonshiue @JDMather picture 1picture 1picture 2picture 2
I apologise for the miscommunication. I will say my problem better this time.
In the attachment you can find 2 ipt. attachments namely double-one and 3-loop. What I can't do is create the same fillet from the 3-loop in the double-one. In picture 1, you can see which fillet I want to create and in picture 2, you can see where I want to have the same fillet. the fillet i want to recreate in de 3-loop is fillet 14, 15 and 16.
Do you have an idea why I cannot do the same fillet as the 3-loop but this time in the double-one? It has a variable rounding and it can select the whole edge and with the double-one drawing it selects only one edge instead of the whole one.
Thank you for your patience.
