Hiding Parts in ISO Section View
I've an assembly, and want to hide some parts to show more internal details...typically, find the part in the browseer, rt. click and turn on/off visability...yet it is "grayed"out and unable to be selected...
I tried to post a screenshot with it, but it won't allow me to shoot the rt. click drop box...sorry!
Cheers all!!
Jess
mdavis22569
Do it with a View representation
Make a new View Rep with only what you want to see ...
Double click the view and pick that View Rep
Mike Davis
Thanks for the info...Im not clear on how to do that within that view...the ISO Section that is....
Secondly, is hiding the part within the ISO Section not allowed...I'm sure Ive seen it somewhere (YouTube I think).
mdavis22569
Go to your IAM .... then to your browser.
Expand your Representation Folder. Should have Master (locked) and Default, Right mouse button and make a New view... Call it View 1, or Iso your choice.
While in that View Rep, turn off all the items you want turned of in the ISO view.
Once you're done turning off everything you don't want .... SAVE the IAM
Click back on Default making it active. Everything you turned off should be back on.
Go to your IDW.  Double click on the View.
In the pop up ... You'll see Views like I post earlier. Click on your new one that you made and close the pop up. You should see an updated view with all the items you wanted turned off .... Off now ...
Mike Davis
mdavis22569
As for is it allowed ..Yes it is ...
are you now able update any of the views?     Is Defered update on?
Mike Davis
SBix26
In the Edit View dialog box, uncheck the Associative check box just above the View Representations list (you can see it in Michael's posting, has a link icon next to it).  Inventor gives you the ability to control component visibility either in the drawing (non-associative) or in the assembly via View Reps (associative).  Looks as if you wish to work non-associative and your view was placed associative, so all you need to do is change that condition.
Sam B
Inventor Professional 2015 SP2
Windows 7 Enterprise 64-bit, SP1
HP EliteBook 8770w; 8 GB RAM; Core™ i7-3720QM 2.60 GHz; Quadro K4000M
Thanks, guys!!  It was the "Associative" relationship...all good now!!
Have a great week!!!
Cheers,
Jess
