Announcements
Hidden lines tough to see
I teach Inventor at a high school and am constantly showing students how to use the program while displaying over a digital projector.
While working on orthographic projections/hidden lines/center lines/etc. I like to switch the visual style to wireframe with hidden edges to provide a quick view of what might be considered the front view of the object.
Unfortunately, while in wireframe view those hidden edges are almost impossible to see over the projector because they blend in with the background of the workspace.
I've gone through all of the various presentation settings under Options --> Colors tab. Is there another way to change the settings for hidden lines to make them have more contrast with the workspace?
I've attached a screen capture. I can actually see the hidden lines just fine on my own monitor, but over the projector they're close to invisible.
Thanks!
jtylerbc
Are they still too hard to see even if you use the "Presentation" color scheme?  It has a white background, so the lighter lines should stand out more.
Based on what you said in your post, it sounds like you may have already tried that, but I just want to make sure you check the super-simple option before you go on to anything more involved.
If that doesn't help, go to the Application Options - Display tab, and click the "Settings" button in the "Appearance" section near the top.  In the "Display Appearance" dialog box, at the top is a setting for " % Hidden Edge Dimming".  This defaults to 70% - the smaller this number is, the darker the hidden lines will be.
For this to be practical, you will also want to set the Appearance to "Use application settings".  If you don't, the dimming setting will still work, but will have to be set individually for every file.
Perfect! I had tried the simple solution but it wasn't cutting it.
I changed the % dimming just like you said and that helped tremendously. The other thing I did was change the background to 1-color instead of gradient. Between the two I'm set now.
Thanks!
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
