hemming a curved surface
Mohammed_Alii
Message 1 of 11
Mohammed_Alii
Hello..
I wonder how can I use hem feature on curved surface so I can make a metal part like that..
considering that: I am using it as sheet metal, so I need to unfold it later.
I have tried sweep feature but it's not working with sheet metal features.
Thanks in advance.
Replies (10)
Message 2 of 11
Lucas.dolinarVFXZU
use contour roll
Message 3 of 11
johnsonshiue
Hi! Lucas is right. For the straight segments, you may use Contour Flange command. For the bent segments, you will need to use Contour Roll.
Many thanks!
Software Test Engineer
Message 4 of 11
IgorMir
It is possible. But not with the Hem feature.
Here is a model in IV2020 format. It can be done neater, of course. I was just trying different approaches in it.
Cheers.
@Mohammed_Alii wrote:
Hello..
Thanks in advance.
Web: www.meqc.com.au
Message 5 of 11
cadman777
Did you try making it without the Hem, then Unfold it, then add the Hem, and then Refold it?
... Chris
Win 7 Pro 64 bit + IV 2010 Suite
ASUS X79 Deluxe
Intel i7 3820 4.4 O/C
64 Gig ADATA RAM
Nvidia Quadro M5000 8 Gig
3d Connexion Space Navigator
Message 6 of 11
IgorMir
It doesn't work. IV2020 part is attached.
Message 7 of 11
cadman777
Thanx Igor.
I know IV2010 won't do it either.
It hems only the flat segments one edge at a time.
Totally worthless!
But I was hoping the newer versions worked.
Otherwise, the way you did it is the way I would have done it.
You make the profile and then keep using it all the way around with ContourBend.
Then to fabricate the part, you make the hem along the edges of the flat sheet before roll forming.
I wonder how the hem would deform during rolling?
What kind of special method would be used to keep it from deforming?
... Chris
ASUS X79 Deluxe
64 Gig ADATA RAM
Message 8 of 11
IgorMir
Hi Chris,
I don't think there should be an issue with rolling the part up. To support the hem - I would roll it up together with the filler plate. Inserted in between the opposite hems. But then again - it is trial and error type of work. To start with anyway.
Cheers,
Igor.
Message 9 of 11
cadman777
I agree.
... Chris
ASUS X79 Deluxe
64 Gig ADATA RAM
Message 10 of 11
Mohammed_Alii
Brilliant solution @IgorMir
thank you
Message 11 of 11
IgorMir
Thanks, Mohamed.
I wouldn't call it a "brilliant solution", of course. But at least - it gives you some sort of direction how to deal with such a design. 🙂
Cheers,
Igor.
thank you
