It seems you have edited the units of the RUN and not of the ROUTE.
I have been investigating this a while back and didn’t have time to search deeply but since this is a recurring theme in the forum I have played with it and found the answer.
It is quite logic as you will see.
Any already created documents need to be manually change by editing that document and using the Tools / Document Settings / Units tab / Length drop-down field. What do I mean by documents? “Tube and Pipe Runs” assembly, any “Run”, any “Route” and it goes the same for hoses.
I think you will only edit the routes really and one thing to understand is that the dimensions will show in the new unit chosen, but when you edit that dimension you will have the original value you entered + original units. For example you created a route with a segment length of 1500mm and then you change the units to inches, then the dimension will report 59.055 but when you edit the dimension you will see 1500mm(mind the explicit units).
Any new files you create will get the units of the parent document. For example if your files were created in mm and you suddenly decide the new Runs or Routes to be inches then you need to first edit its parent document.
If you need to create all new Routes in inches then you first need to edit the parent Run and set it to inches.
If you need to create all new Runs in inches then you first need to change the “Tube and Pipe Runs” document to inches.
HOWEVER any generated pipe segments will have the units set as per CC (Content Center) family settings. Using ASME pipes will get you inch lengths of pipes while using DIN, ISO, etc. styles will generate metric lengths. No matter what units you have in the T&P assembly, Run or Route the pipes will use the CC family units.
BOM and drawing Pars List will get units from the pipe segments so if you have mixed styles (metric, imperial) then you will get mixed units.
To emphasize this you can add a “BASE UNIT” column on the parts list which should help spotting different units.
Using Material Lists with cumulated lengths is safe since you are probably merging the parts by stock number or part number and those groups by same “unit” type. Hope I am not confusing you here.
Back to the assembly environment, you can either open the documents or edit them in the current assembly. Some documents are tricky to open like Routes which can only be open either using the open command and browse for it on disk, or by selecting it in the browser or graphical window and then use “right click on graphical window” and choose “open”. It’s the only way to open a route as a separate document.
TIP: Here’s how to save documents if the main assembly is open. If the main assembly is open and you decide to open a run, route, separately then you need to do the changes in the open document but save the main assembly. Some files can only be saved in the context of the main assembly.
Good Luck.
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
