Help with Sweep
Help with Sweep
karmat.dorji.22
Message 1 of 8
Help with Sweep
karmat.dorji.22
How to sweep path with path in 2023 or how to change to sweep type in inventor 2023?
Replies (7)
Message 3 of 8
JDMather
Attach your file here.
Message 4 of 8
karmat.dorji.22
Due office work i cannot share the drawing, sir.
In older version, the is option to change sweep type like path, path and guide rail.
How can we change in inventor 2023
Message 5 of 8
karmat.dorji.22
Thank you and i couldn't find to sweep line to line (path-path way)
Message 6 of 8
JDMather
Make up dummy file.
Message 7 of 8
johnsonshiue
Hi! I assume you are looking for Guide Rail Sweep. The option has been consolidated to Guide Sweep. You can select a path or a surface as a guide.
Many thanks!
Software Test Engineer
Message 8 of 8
karmat.dorji.22
Yes sir.
Thank you so much. It worked
