HELP WITH SPRING MODEL
JimmyRecard
JimmyRecard
I'm really struggling with a model for one of my company's W spring designs.
I'm under the impression I need to use a 3D sketch but I'm unfamiliar with using this technique and cant get my head round it.
If anyone could help me with this design it would be much appreciated!
JDMather
I have attached this exact spring here in the past, but I have no idea how to find the prior thread.
You should mention what version of Inventor you are using (especially when using an very old version 2017).
JimmyRecard
Im using inventor professional 2020
JDMather
iProperties of the file that you attached here indicates 2017.
So then I did >>a search<< and found where you asked this question before.
(You might have mentioned this fact.)
I would have posted this file back then if I had known you were using 2020.
Most of the spring is from 2D sketches, with a portion from 3D sketch intersection.
Can you post image of your About Inventor to verify what version of Inventor you are using?
JimmyRecard
Apologies the file was saved from inventor 2017 but my company has since updated to inventor 2020
IgorMir
Hi Jimmy;
Attached is the model of the spring in IV2020 format.
Dimensions are at random. I just didn't want to muck around with the imperial units.
But I hope - the model will give yo a direction to follow.
Cheers,
Igor.
Web: www.meqc.com.au
