Help with .obj file
Help with .obj file
Lebotec
Message 1 of 9
Help with .obj file
Lebotec
I was wondering if anybody could help me convert a .obj file in to a solid.
I've tried it but with no luck, the mesh enabler fails.
Hope someone can help me turning this file in to a usable solid.
Many thanks!!
Joost
Replies (8)
Message 2 of 9
89198826955
this is better done with meshmixer
converted stl file attached
Message 3 of 9
blandb
I don't see an attached file?
Autodesk Certified Professional
Message 4 of 9
89198826955
a
Message 5 of 9
johnsonshiue
Hi! Inventor has fairly limited mesh modeling ability. I suggest you look into Fusion 360, where there is a dedicated Mesh Design environment. You may repair the mesh and convert it to a smoother solid bodies.
Many thanks!
Software Test Engineer
Message 6 of 9
hfcandrew
You file was not at all solid/watertight/fixed:
See attached for a slightly better fixed model, still lots of floating bodies though:
Message 7 of 9
Lebotec
Hi Andrew
Many thanks for your effort!!!
But I'm affraid it is still not a very usefull model.  And it needs to be scaled 10 times bigger.
I'm going to try it with Fusion like @johnsonshiue suggested.
Never the less many thanks!!  ( also for everone else who replied)
Best regards,
Joost
Message 8 of 9
hfcandrew
I'm curious how well fusion360 can auto-repair that. When you do could you post the repaired .stl?
Message 9 of 9
johnsonshiue
Hi! The success of any geometry repair workflow depends on how bad the geometry is. Also, it may depend on the sequence of operations. It is a bit trial and error. Please feel free to try the Mesh Design environment in Fusion 360.
Many thanks!
