Hello JDMather,
Thanks for the reply and sorry for such a delay response to your answer. I was on vacation and playing catch up at work the last few days.
I'm using Autodesk Inventor Professional 2020.
My main objective is to better myself using Dynamic simulation since I haven't never really used it in a real scenario and been using Inventor daily since 2009. Plus I want to see if I can answer a few unknowns I have with a current project.
The assembly I gave was a dumb down version of project assembly, hoping it would make it easier to simulate. The gravity is in the right direction, and I don't really remember what I was trying to accomplish with editing the prismatic #1.
Now for my objectives for dynamic simulation and what the project scope is.
Scope of work is to implement a in 100% width check in a process. We will use LVDT sensor to measure the displacement of the of the cylinder jaws to determine if part is Ok or NOK and separate as required. We will also use the data collect to build SPC run charts to measure the process capability.
What I would like to accomplish is to show a simulation of the process working. I usually do this using assembly and drive constrains, then create different positional representations then go into inventor studio to create animation.
I was hoping I would be able to do all this in Dynamic simulation, and see if I can get the vertical movement from of the mounted guided cylinder from the reaction force of the cylinder retract to move the upper jaw into position. The mounted guided cylinder is mounted to linear rails to have compliance to float for part variation.
Second I want to ensure gravity will be enough to return the back home if the bearings fail for some reason, or is not maintain properly, and we 're confirming the group return by using a smart stop before retracting the vertical slide cylinder. I been kicking around the idea of adding a gas spring to assist the in returning the mounted guided cylinder home.
Third I would like to do the export to FEA to measure the displacement of the jaws under load. I usually just perform this in the model state, but would like to see how the work flow works in dynamic simulation.
Let me know if you would like the complete assembly as is currently.
