Help on making gridded patterns in sheet metal.
Assuming this piece of sheet metal was completely rectangular, with no pieces cut out, how did the creator of this design the gridded pattern? I would like to do the same to another piece of sheet metal.
johnsonshiue
Hi! If I were you, I would start with the grills first without creating any rectangle or hole or round. After the grills are created, create the boundary and start drilling holes. This would make your life easier in terms of sketching. Don't try to create a massive sketch like this. You will run into issues and editing can be painful. Another way is to create a sketch block representing the rounded square. You can pattern the sketch block to create the grill. Then worry about the boundary and holes later.
Also, it would not surprise me if the original designer created the 2D profile in AutoCAD and imported it to Inventor.
Many thanks!
Software Test Engineer
salariua
...nothing to add except some rare resources on the topic, which are kind of hard to find but I find them really interesting.
a screencast
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
mcgyvr
Sometimes in life you have to do hard work...Smiley Wink
No easy button for everything yet thankfully..
JDMather
To elaborate a bit on what Johnson said - in case you have never used this tool, this is Grill...
