Help on dynamic simulation coupling between axes
Hi everyone. I am but a beginner in Inventor. And I really don't know what to do next...
Clarifying,
I wish to run a dynamic simulation between a coupling.
the driving machine (the yellow one) is connected to the driven(the red one) by a coupling. It is basically a pair of disks with cylindrical bodies made of rubber attached to them that are pressed together to form the coupling
So I made the rubbers and the couplings each and then I assembled and constrained them. I did later a new assembly to create the coupling between both of them and I also constrained them:
I would like now to create a dynamic simulation to see the stress developed on the rubbers, however this is where I really don't know how to proceed..
- Should I put a 3d contact type of joint? and If so, is there any way to select the rubbers' faces and the couplings' holes
- Do I need to add more elements, perhaps to tell inventor which parts or elements are fixed or grounded?
- Later on, I want also to do the dynamic simulation and introduce a variation in both axes so they are misaligned. Is this also possible?
I am attaching the assembly as well
and please tell me if you guys understand me, english is not my main language but hopefully I can explain anything that is not clear.
