This forum needs a draft option - page just refreshed on me and lost my mostly completed post... that aside.
I am using Autodesk Vault/Inventor combo - Inventor 2020.3.2(373), and Vault 2020.2(25.2.83.0).
I am having issues with an Inventor assembly which is telling me to update a bunch of parts in the vault - which were previously saved, checked in, and some parts were already existing in the vault as Locked geometry. It is a number of the locked models, bolt/screw/washer components, in our standard components folder in our Vault. I had spent a copious amount of time(more like wasted my time due to Inventor incompetency's) going through the model to make sure all assembly/parts were updated prior to checking in - cause the rebuild doesn't always update fully through the model and save properly - especially the IPNs. After checking in the whole assembly, I deleted all local files related to the assembly I was working on, and then did a "get" on the whole standard parts folder where the Hardware is referenced from. After opening the assembly, I am now getting all kinds of errors saying that I need to rebuild my model...WHAA>>!!?? And most of the components are the bolt components in the locked/standard components folder - which I did a get on...
What in the process of inserting a part into an assembly would conceivably force a model - a locked component file - to require an update? Best part is, that sometimes it will only show a few models that need it to start, and then you rebuild, and then more need it all of the sudden.
Any help? Inventor is becoming such a colossal waste of my time at work... I should be Inventing models, not ways of work-arounds for the program I am working with!
