Help finding PEEK Plastic as a material
Hey all,
I am striking out searching for PEEK (Not PAEK) Plastic in both the Autodesk & Inventor Material Library.  Where can I find it?
Thanks!
JDMather
Do you have Inventor Professional with the Mold Environment?
I found 43 PEEK materials in a Search.
While I have Inventor Professional, I am unsure if I have the Mold Environments or not.  How could I check if I do or do not have it?  My search turned up nada, so I am guessing I do not have Mold Environments.
JDMather
If you have Inventor Professional - you have Mold Environment.
Where are you searching for "PEEK"?  No where I have tried to search for it in Inventor has turned up any results.
Ok.  I definitely have Mold Environments.
mcgyvr
@Anonymous wrote:
Hey all,
Thanks!
The material/appearance libraries are not all inclusive with every material and appearance in the world..
They only give you a sampling of some "common ones" and if you use a different one you need to add it yourself..
I think this should cover the procedure..
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/Inventor-Help/files/GUID-6F090B0A-F28C-4165-A4D2-63C89D086B81-htm.html
