Having Problems Turning Complex Solid into Shell
I am trying to turn the attached file into a shell in order to be able to save material while building it using 3D printer. Till now I did not manage to do it.
Can anyone help me achieve this? Preferably the thickness should be at least 5 mm. I would appreciate if you will show me the steps as I would be needing to do this for other complex shapes.
(the object was downloaded from another website)
Thanks a lot!
WHolzwarth
No easy task.
- No luck with Inventor
- No luck with Fusion360
Rhino showed an acceptable result with 2mm thickness. I didn't try 5mm.
See attached 2016 IPT. EOP needs to be pulled down again
Walter
Later: Meanwhile I tried 5 mm offset, too. Not all of the surface members were offset, but about 95%
Walter Holzwarth
WHolzwarth
Smiley Wink I've placed - hopefully not buried - an entry in IdeaStation.
http://forums.autodesk.com/t5/inventor-ideas/improved-surface-offsets-needed/idi-p/6601414
Walter Holzwarth
Thanks for your reply. Indeed it is difficult as I didn't manage to do it in inventor.
I voted your post in the ideastation
WHolzwarth
Congratulations.
Smiley Wink You're the fastest voter.
Walter
Walter Holzwarth
