Hatch Setup & Edit in IDW
MikeKovacik4928
Advisor Advisor
Message 1 of 11
MikeKovacik4928
Hi all
Just want to find out the most efficient way of setting up and editing hatch patterns in idw's in inventor.
Over the years, I have usually just accepted default hatch pattern and edited singly any new ones I want.
But when there are lots of sectioned areas to change, this becomes a bit tedious.
Lately I have been trying a few things, see attached PDF's.
I have now set up hatch patterns, and even layers to get the colour, because
the custom hatches don't allow colours.
Read the pdf's and comment. I would like to hear how everybody else deals with this
Michael Kovacik
Draughting/Designing (Manufacturing) (31 yrs)
Drawing Board (3 yrs)
Cad (28 yrs)
Cadkey (4 yrs)
AutoCAD 2d & 3d (16 yrs)
Inventor (4 yrs)
Autocad and Inventor Simultaneously (4 years)
(and recently Autocad/Inventor Customisation)
Autodesk Product Design Suite Ultimate 2018
Autocad 2018, Inventor Pro 2018
Johannesburg, South Africa
(Impossible only means you haven't
found the solution yet)
Replies (10)
Message 2 of 11
mcgyvr
Some good info here..
https://forums.autodesk.com/t5/inventor-forum/hatch-patterns-explained/td-p/6243656
and here too
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/AutoC...
Message 3 of 11
MikeKovacik4928
I know how hatch patterns are made. Thanks for the links.
If anyone is interested I have some tutorials I wrote in 2005 on Creating Custom Hatch Patterns and Installing Custom Hatch Patterns.(for AutoCAD)
These were based on an earlier version of autocad, so I don't know if anything has changed with Custom Hatch Patterns, as I haven't done
anything on custom hatch patterns since then.
If there is somewhere I can upload them, I am willing, they are word files (1 MB & 170KB), I don't know whether I can load them here?
What I am actually looking for is a nice quick efficient way of making the right hatch patterns
appear in the idw (ie wood for wood, steel for steel, concrete for concrete) without having a standard hatch pattern at a 1:1 scale
appear in every single section of every single component of every single view, and then having to edit each and every instance.
In my PDF's attached I have explained in detail how I use to do it, and how I go about it now.
Michael Kovacik
Cad (28 yrs)
-Cadkey (4 yrs)
-AutoCAD 2d & 3d (16 yrs)
-Inventor (4 yrs)
-Autocad and Inventor Simultaneously (4 years)
Message 4 of 11
johnsonshiue
Hi Mike,
I am sorry I may misunderstood your request. From time to time, I do have human multi-threading errors. Please bear with me. I thought this could be done already via Material Hatch Pattern Defaults in Styles Editor -> Standard -> find the tab on the right. There you could load a part with various materials. Then assign different hatch pattern for each material. Now, when you create section views of the parts, the correct hatch pattern will appear. Please take a look at the following Help document.
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2018...
If it does not work for you, could you provide an example showing me the behavior.
Many thanks!
Software Test Engineer
Message 5 of 11
MikeKovacik4928
This looks like what I want to do.
ie assign a hatch pattern to a material which is assigned to a part,
therefore the part automatically gives the correct hatch pattern
when sectioned in an idw.
Scaling maybe, has to be done individually per view?
I will investigate and let you know
Michael Kovacik
Cad (28 yrs)
Cadkey (4 yrs)
Inventor (4 yrs)
Message 6 of 11
Dnyaneshwar_Maid
Hi
If I understand you need to use two or three type of hatch styles. Let say name is Wooden, Steel and Concrete Hatch
If you want to use wooden hatch style 40 times and rest of two styles very less time then have you tried to make the wooden hatch style as default hatch style?? Please see below image in Style and Standard Editor.
What I am suggesting is you need to define different hatch styles and layers which you already done and just set default hatch which you mostly use.
Also if need to use it again and again in each drawing please do not forget the save the Style Manager with this setting. I think you know this setting!!
Best regards,
Dnyaneshwar Maid
Dnyaneshwar Maid
Design Engineer @MIBA,
Student Expert@Inventor
Message 7 of 11
MikeKovacik4928
I am still investigating.
it looks like I can achieve what I want with a whole bunch of settings,
like object default, layers, default standard, assigning a hatch to a material etc.
To those who contributed, thanks, I will give kudos.
There was however no definitive answer given,
so I will not be posting "accept as solution"
Michael Kovacik
Cad (28 yrs)
Cadkey (4 yrs)
Inventor (4 yrs)
Message 8 of 11
MikeKovacik4928
Even when assign a hatch pattern to a material, it still doesn't
help when you have a section with a whole bunch of areas
where you either have to change the hatch scale or the colour
or both. You still have to edit each one separately, if you select
more than 1 the edit button is greyed.
I really do wish for the autocad "paint properties"
command here. Either that or allow multiple selections of
areas so they can all be changed at once to required scale
and colour.
If there is not another existing solution, which there doesn't appear to be,
and if anybody agrees with me that this would be useful,
I will submit it as an IDEA
Michael Kovacik
-Drawing Board (3 yrs)
--Cad (28 yrs)
---Cadkey (4 yrs)
---AutoCAD 2d & 3d (16 yrs)
---Inventor (4 yrs)
---Autocad and Inventor Simultaneously (4 years)
---(and recently Autocad/Inventor Customisation)
(personal licensed copy)
Message 9 of 11
johnsonshiue
Hi Mike,
I thought my suggestion would work. It does not sound like the case. Do you mind sharing a simple example? I really want to understand this request better.
Many thanks!
Message 10 of 11
MikeKovacik4928
Johnson
yes your suggestion has solved some of what I wanted,
but not everything that I wanted to achieve.
It could still  be that it is possible in inventor.
There are still some areas I haven't investigated yet.
It will take me a while to come up with a document I
can post here.
Like I said,this is all done in my lunch hour, and spare
time at home with my own software, which is why
my posts are all delayed and take time.
I don't know whether it is different in your part of the
world, and whether employees would be allowed to
do this in company time?
Michael Kovacik
--Cad (28 yrs)
---Cadkey (4 yrs)
---Inventor (4 yrs)
Message 11 of 11
MikeKovacik4928
Okay finally
Still no solution to changes numerous hatches all at once, in terms of scale and colour.
This is adding significant extra time in getting my drawings out
I would like to add the idea of either
1. being able to match properties of hatch patterns (like in autocad)
 or
2. being able to to a multiple select without the edit button being greyed out,
     so that you can edit a whole pile of hatches at one go to a single setting
but the 1st idea already exists, and is the one I prefer, although both would solve the problem,
therefore I will just add my vote.
See attached for a full explanation of what I have tried and what I have seen on
the idea forum
Michael Kovacik
Cad (28 yrs)
-Cadkey (4 yrs)
-Inventor (4 yrs)
(My own personal licensed copy)
