Hatch Settings
Hatch Settings
MikeKovacik4928
Advisor Advisor
Hatch Settings
MikeKovacik4928
Greetings All
See embedded jpeg's explaining my problem
I want to know how to use the By Material Function for Hatch Patterns,
and also find out from other Inventor Users how they manage their hatching.
I use the default hatch and change every single instance in the idw to suit.
Definitely not the right way, and very tedious. I want to change to the correct, more efficient way.
Michael Kovacik
2d & 3d Autocad and Inventor designer/draughtsman
Draughting/Designing (Manufacturing) (31 yrs)
-Drawing Board (3 yrs)
--Cad (28 yrs)
---Cadkey (4 yrs)
---AutoCAD 2d & 3d (16 yrs)
---Inventor (4 yrs)
---Autocad and Inventor Simultaneously (4 years)
---(and recently Autocad/Inventor Customisation)
Authorised Autocad & Inventor Professional
Authorised Autodesk Trainer
Higher Diploma Mechanical Engineering
Autodesk Product Design Suite Ultimate 2018
Autocad 2018, Inventor Pro 2018
(personal licensed copy)
Johannesburg, South Africa
(Impossible only means you haven't
found the solution yet)
johnsonshiue
Hi Mike,
If I understood your request correctly, you could set up your own Styles and have each material mapped to a hatch style. Here is a video showing the workflow.
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/screencast/Main/Details/...
Many thanks!
Software Test Engineer
MikeKovacik4928
Thanks Johnson
That is exactly what I was after.
I can't believe that after 8 years of using Inventor, I am still learning brand new
things on an almost daily basis!!
That just goes to show, you are  never too experienced, and you are never a total expert,
and you must always show a willingness to listen and learn.
The Forum Rocks!!
Mike
johnsonshiue
Hi Mike,
I totally agree with you. I also learn a lot from our users like you everyday. Learning is mutual. It only helps make the product better.
Many thanks!
