Guided Tutorial not loading
Kind of at my wits end with this issue, and not really sure where else to look for answers.
I am a technician for a school system and have a unique issue with Inventor. An instructor utilizes the Guided Tutorials within Inventor to assist her in teaching how to use the program, and since recently upgrading our machine to Windows 10 she has been unable to use these tutorials. Upon attempting to load the tutorials under a student's account (which is heavily restricted rights-wise) the tutorials do not load properly and they are greeted with the error message:
Failed to load URL http://localhost:44441/guided-tutorial-plugin/v2/engine#/play/INVNTOR/2018/ENU/Part%20tutorial%202?channel=guided-tutorial-response-channel-000000?mode=enabled?user=hoggard.student?tutorialLanguage=ENU with error A connection attempt was refused. (-102).
The troubleshooting for this error that I can find was to re-install the Guided Tutorial plugin, which I have tried and has not resolved the issue. The other solution I found was to make sure firewall/proxies were disabled, but that has been tried as well without success.
What I have noticed through extensive troubleshooting is that the two "Node.exe" processes required for the Guided Tutorials are not starting when Inventor run under the student account. If I run Inventor under any other account (Teacher or Admin, either work fine) the "Node.exe" processes start as they should, and the Guided Tutorials work without issue. Also, if I manually start Node.exe and leave it running as a desktop program, the Guided Tutorials work properly when launched from the student account.
My question is: Is there some kind of logging that I can enable within Inventor to try and see why the two "Node.exe" processes are not starting properly? I know there must be something that is stopping them from starting, I am just unsure of what that something is.
Pat
