As illustrated in the attached video, the second tab from the left can't be selected for some reason. It doesen't matter which sub-assembly it is either. Second tab is just "unclickable". Right-click -> open from the 3D space or the model tree works just fine...
I am aware that Windows 11 isn't yet fully supported, but I assume it will be in foreseeable future, so I find it worth reporting regardless...
Thank you for reporting this. I have notified the team of this issue and so far we havent encountered this issue. I have personally played around with Windows 11 on our beta builds but have not seen this behavior. Selection of all tabs works fine.
If you are a member of our beta program, you can try it out our beta release and see if you can reproduce it . If not you can send me your sample dataset and I am happy to test it for you - you can attach the files here or you can email it to: sundarsATautodeskDOTcom.
-shiva
For the next re
I haven't had the issue lately either. Never found out what was causing it though.
Thanks for the update. Please update this post if you see it again and have steps to reproduce.
Have a great day!
-shiva
