I would like to create a grid pattern on a rectangular object. I followed this video explaining how to use the grill function and the rectangular pattern function as well for my design.
So far I have successfully created duplicates of this design, but now I ran into some issues now for some reason.
Whenever I go to this step now (as shown in picture labeled 1) where I have created the pattern, I can't select my boundary now for some reason. Yet, when I create my boundary only (no pattern), I am able to use the grill function.
What is going on here and how can I fix it?
@Anonymous,
marius.gildehaus has edited your subject line and embedded pictures for clarity
Original: Grill issues
Solved by johnsonshiue. Go to Solution.
Hi! I believe the problem is with Sketch23. The rectangle (boundary) has overlapped segments and also it is not properly constrained. I deleted it and recreated it with a new rectangle. It seems to work now. Please take a look at attached part.
Many thanks!
Hello @Anonymous!
Could the fix from @johnsonshiue help you?
If yes, please mark his post as solution so other users can benefit from that.
Thanks!
Sorry about the late response. Are you able to describe as to why it wouldn't work in a little more depth? Whenever I try to create a rectangle on the same flat surface (removed the grill) the grill function won't work and I don't know what to do to fix it.
Hi! It has been a while since I provided the solution. It could take some time for me to find out the difference. The quickest way to find out is to compare the part I attached to yours. It should not be too hard to find out.
Many thanks!
That's what I tried to do but I couldn't find any difference between the two.
I attached the model I'm trying to do. Even when I just create a rectangle sketch initially on the surface, the grill function won't work so I can't see any constraint problems or overlapping segment problems mainly because I'm not sure what to look for exactly
Hi! Like I mentioned earlier, there are overlapped line segments. The square contains a small segment on top of it. Also one or two of the grill lines have similar overlapped segments too. You need to delete them. I simply deleted the square and deleted the short segment. Then recreate a square. Also you need to make sure you enter logical width and height for the Boundary and the Rib. That is all I did in the part I attached.
Many thanks!
