Graphics problem specific to certain assemblies
george0621
george0621
The graphics in Inventor looks strange in certain assemblies (see attached figure). Any tips on what the cause of this could be?
I've tried the following with no improvement:
  • Changing the Graphics Settings in the Hardware tab in the Application options to quality and performance.
  • Disabling express mode.
  • Restarting the application and workstation
Because it's only for one assembly, are there document level graphic settings to be adjusted?
Replies (7)
CGBenner
@george0621
Hello, I would check the lighting settings for this assembly and see how they compare to others.  Has someone inadvertently made a change to the lighting?
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
george0621
@CGBenner
Hi, thank you for the response. I've compared the lighting settings, it looks like there hasn't been any change unfortunately. Are there any more lighting settings to check apart from the "Active lighting style"?
johnsonshiue
Hi George,
This looks like that components are very far away from the origin. Please measure the distance between a vertex on one component and the assembly origin.
Many thanks!
Software Test Engineer
george0621
@johnsonshiue
Hi John, that worked! Thank you very much! Do you know why being away from the origin causes this?
CGBenner
@george0621
Hi George, it probably has to do with the distance that the default lights are from the origin, so as you get farther away it is creating "shadows".
Chris Benner
johnsonshiue
Hi! Inventor is a true-scaled modeler. It means that the geometry created in the model space is true to the size regardless of measure unit. If something measures 1 km, it is indeed 1 km in length. The graphics system has to represent the geometry to high accuracy regardless of the size. However, as geometry is located further away from the origin, the amount of resource required to display it in high fidelity becomes much greater. With a fixed hardware resource, the fidelity will go down accordingly.
Many thanks!
george0621
Great explanation @johnsonshiue, thank you very much!
