Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
The graphics in Inventor looks strange in certain assemblies (see attached figure). Any tips on what the cause of this could be?
I've tried the following with no improvement:
Because it's only for one assembly, are there document level graphic settings to be adjusted?
Solved by johnsonshiue. Go to Solution.
@george0621
Hello, I would check the lighting settings for this assembly and see how they compare to others. Has someone inadvertently made a change to the lighting?
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Also be generous with Likes! Thank you and enjoy!
Hi George,
This looks like that components are very far away from the origin. Please measure the distance between a vertex on one component and the assembly origin.
Many thanks!
Hi John, that worked! Thank you very much! Do you know why being away from the origin causes this?
@george0621
Hi George, it probably has to do with the distance that the default lights are from the origin, so as you get farther away it is creating "shadows".
Chris Benner
Hi! Inventor is a true-scaled modeler. It means that the geometry created in the model space is true to the size regardless of measure unit. If something measures 1 km, it is indeed 1 km in length. The graphics system has to represent the geometry to high accuracy regardless of the size. However, as geometry is located further away from the origin, the amount of resource required to display it in high fidelity becomes much greater. With a fixed hardware resource, the fidelity will go down accordingly.
Many thanks!
