I am about to make a lot of assemblies, they will be very similar to each other, all the principles will be the same, and so will a lot of parameters be. Problem is, these "global" parameters might still change over the course of the project. I don't want to have to open every single part/assembly and edit the parameters manually, this would take a long time, and mistakes would be garanteed. Would it be possible to compile a list of these parameters in an external rule or some other external file, change the values there, and run the rule in all assemblies to change all parameters at once?
I feel like this shouldn't be too hard with a simple Ilogic rule, but I have no idea where to start.
