So I have been having some issues using the frame generator in inventor and trying to get the true length of a frame member when it is trimmed/coped into the corner of two other members. Some of the items are only an inch or so out which is fine as it is always longer but some frames I work with the generated length is up to a foot longer than the true length. Our BOM is auto populated with the length as the G_L of the beam so we are giving the shop incorrect raw cuts which is going to waste material. Is there some workflow I don't know about or am missing to make this correct? I am using the Trim/Extend command to get the members to the right length then I use the notch command when needed. It seems to be the trim/extend command that is causing the problem and pushing the start and finish work planes way out into space.
