Announcements
Getting rid of yellow lines on imported STEP
Mustang69
Mustang69
Have this model I got from a manufacturer but for presentation it has yellow lines I cant remove
Am I stuck with them or is there a way to get rid of them?
Replies (7)
JDMather
@Mustang69
You have surface bodies.
Convert to solid bodies or change Application Options Edge Display.
Can you Attach the original file here?
Mustang69
Yes I know it comes up that way when opening the STEP file I got
Tried different ways but same result
How do I convert to solids?
Here are the original file
Mustang69
Hmm!! When I put in the part in my assembly it looks just fine!
Only when I open the separate part the lines appear.... Is there some setting differences in IPT or IAM files?
JDMather
I forgot to ask what version of Inventor you are using.
Mustang69
Gabriel_Watson
Unfortunately, you will have to rebuild/repair too much of this to make it work as a solid ("Stitch" it back together as a solid body instead of a surface). You are better off reconstructing another simplified solid that represents the largest geometrical boundaries of the part to use this in your assemblies.
I did a quick repair here in the Repair Environment and after a few passes using the Heal command I fixed the initial errors, but you still have underlying fundamental issues, which honestly happen a lot from vendor-type downloadable components you get online. Simply put, these are missing key surfaces that you have to add manually yourself, and it looks like there is at least a full day of work for you to fix this part:
johnsonshiue
Hi! If you don't mind them being surfaces, you can simply set the visual style to Shade (no edges) in the Part. It should look exactly the same as how it looks in the assembly.
Converting it to a solid requires additional work. Depending on the body quality and the gaps between the surfaces, you may or may not be able to convert it to a solid body.
Many thanks!
Software Test Engineer
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
