Getting error message " Projection of assembly is required on a drawing view"
ashokchudasama
Message 1 of 17
ashokchudasama
I just created a new part (not assembly) and tried to created new drawing for this part. When I click on "Part List" icon, I am getting this error message.
" Projection of assembly is required on a drawing view".
Actually I have not created assembly and not used any assembly drawing template than why am I getting this error. I am seeking help if something in the setting need to be changed.
Accepted solutions (4)
Replies (16)
Message 2 of 17
DSilver4773
do you have any views on your drawing? If not, it won't know what pars list to retrieve. I think that's why it's asking you for a view.
Message 3 of 17
kacper.suchomski
Hi
The parts list needs an assembly view to fetch the data into... the parts list.
The parts list is for the assembly. Does not apply to parts.
On one drawing (or even on one sheet) it is possible to place projections from many files (including many assemblies).
Therefore, when creating a parts list (nomen omen a table), the program asks you to indicate the projections from which it is to download information (because there can be many assemblies on one sheet).
It won't work without it. This tool is for assemblies and requires its presence to function.
Kacper Suchomski
Message 4 of 17
ashokchudasama
Thanks for your help...
I have views on the drawing. This is not an assembly, but a single part (.ipt). I tried with difference parts and tried the same, but get the same error message. This proves that there is nothing wrong with the ipt part.
Message 5 of 17
DSilver4773
You cannot create a parts list for a single part on a drawing. The drawing has to contain an assembly as kacper mentioned.
Message 6 of 17
kacper.suchomski
Simply to create a parts list that applies to an assembly, you need the assembly so that the list can refer to it.
Kacper Suchomski
Message 7 of 17
ashokchudasama
Thanks for your reply...
I only have one part and it's views. There is no assemblies opened on my inventor screen nor I have in my computer at all.
Message 8 of 17
ashokchudasama
Thanks for your help…
Message 9 of 17
ashokchudasama
Thanks for your reply…
I only have one part and it’s views. There is no assemblies opened on my inventor screen nor I have in my computer at all.
Message 10 of 17
ashokchudasama
Thanks...
I need the raw material used for this part. The tab "part list" can also be utilized for single part that will list the raw material.
Message 11 of 17
kacper.suchomski
No. The parts list tool only works with assemblies. If you want to describe the material, you can do it manually or design your own title block that will include this parameter.
Kacper Suchomski
Message 12 of 17
ashokchudasama
We get this kind of result for single part drawing. I took this screen shot from another computer who is using inventor. I copied everything from that computer in setting, but no success.
[cid:image001.png@01D94DD2.9417F810]
Message 13 of 17
ashokchudasama
Message 14 of 17
kacper.suchomski
It's more of a one-part assembly.
If you really must use this list, it's a good solution.
Kacper Suchomski
Message 15 of 17
Bill_Bogan1
It is likely that a single part assembly was created and used for the drawing, which would allow the use of the parts list.
That means you create two files for every single part - quickly becomes a nightmare for file maintenance.
You may want to create a User Defined Symbol with text that pulls the information into the symbol.
Bill Bogan
Principal Content Experience Designer
CXD
PDMS-DiD-Digital Manufacturing
Autodesk, Inc.
Message 16 of 17
ashokchudasama
The part was created and not assembly. It has .ipt extension.
Message 17 of 17
Bill_Bogan1
Then it was my error. I was illustrating that it is possible to put a single part in an assembly and then use the parts list.
If a Part file was used to create the drawing view, then, I think the object is a general table made to look similar to the parts list.
Bill Bogan
CXD
Autodesk, Inc.
