Get text part from the Drawing file name and without extension
ARamos08
ARamos08
Hi all,
I have my inventor Drawings that are saved like this: PESTM-DW-02022020123456.idw
It is just a random number base on date and time.
For my Title Block I want just part from the text file like this: DW-02022020123456.
It is always the same text metric without the file extension.
lena.talkhina
Hello @ARamos08 !
Welcome to Autodesk Inventor community!
Great to see your questions hear. Hope you find a solution soon.
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Лена Талхина/Lena Talkhina
Менеджер Сообщества - Русский/Community Manager - Russian
arkelec
iLogic can get the filename without the extension:
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2015...
You'll need to create a custom property (mine is called c_File_Name), then read that in the title block.
iProperties.Value("Custom", "c_File_Name") = iFileName
iFileName = ThisDoc.FileName(False) 'without extension
Not sure about the leading characters "PESTM" though.  I think in VB.net, you can select text by excluding a number of characters from either end of a string.
You might struggle with this if you are new to iLogic.  I do.
mcgyvr
@ARamos08 wrote:
Hi all,
Is the "PESTM-" always going to be a consistent 6 characters that you want to remove from the beginning? Or could it be 5 or 7 or whatever? If it could be more do you always just want to remove up to and including the first "-"?
If PESTM- is always going to be consistent 6 characters then this code will trim that out..
'Create a new custom iprop of the filename without extension and remove the first 6 characters of the string
iProperties.Value("Custom", "FileNameNoExt") = ThisDoc.FileName(False).Remove(0, 6)
skipmcnoob
Could you describe this step by step? I'm having trouble following your example.
Where should I add custom property rule? To my part template or to my drawing template?
How can I call this custom property in my drawing title block section instead of the default file name that includes the extension?
Help with this would be appreciated.
Cheers!
arkelec
Hi @skipmcnoob
1.  In your part/assembly, create the custom iProperty  "c_File_Name" (click iProperties>Custom)
2.  Save the file.
3.  Populate the custom iProp with using the code:
Sub Main ()
	Dim oDoc As Document = ThisApplication.ActiveDocument
End Sub
4.  In the drawing, add some text:
5.  Select in the left hand drop down box "Custom Properties - Model".
6.  Select in the right hand drop down box your custom iProp "c_File_Name".
The Filename from the part is now shown, without the filetype extension.  You can integrate this into your title block by using the same principle, either with new text or modify the existing text field.
Hope this helps.
P.S.  There is code available to automatically add the custom iProp in the part or assembly file, if it doesn't already exist, but if you add the custom iProp to your templates, you won't need it.
