Get Contrains and Joints info from Inventor to a json file
peter_vascoU
Observer Observer
peter_vascoU
Observer
Observer
Using manual iLogic commands with VB.NET, is it possible to access all the information about constraints and mates, for example? I know it is possible to create them, but is it also possible to read that information and save it to an external file?
The goal is to open the machine CAD in a game engine, such as Unity, and import the constraint and joint information in order to understand the mechanics and movement limits of an industrial machine, without needing to program everything manually in Unity.
Thank you!
kacper.suchomski
This is a duplicate of this post:
https://forums.autodesk.com/t5/inventor-forum/export-contrains-and-joints-from-inventor-to-do-a-digi...
Kacper Suchomski
peter_vascoU
Observer
Observer
Hi! This is a different approach. The first method is about exporting directly from Inventor, while the second is about doing it manually through a script.
