Generate a flat pattern with the dimensions for an eccentric cone from an AutoCAD file?
carlosrealyv
Observer Observer
carlosrealyv
Observer
Observer
I need some help producing a plat pattern for the 18" x 30" eccentric reducer section only from the attached AutoCAD drawings. The cover is 1" thick so there will be a one-inch offset to the current piping dimensions. Can anyone help? If you need more information please let me know. Thank you.
kacper.suchomski
Hi
Here are instructions on how to create components from a multi-body part file (to create a flat pattern, the plate files must be individual).
https://help.autodesk.com/view/INVNTOR/2025/ENU/?guid=GUID-F2EE11BB-857D-4426-9622-ED8EB54123B5
Inside the part files you will be able to create flat patterns for individual sheets.
Kacper Suchomski
SBix26
An eccentric reducer as drawn will not flatten, because it is not a purely conical form-- some material stretching would be needed to create it from a flat sheet.  It is possible to use a trimmed cone to approximate the form, but the ends will not be perfectly circular.  In actual practice, nobody would notice because sheet metal isn't that exact anyway.
I would create one for you, but I don't know what version of Inventor you're using (always include that information in the first post!).
Sam B
Inventor Pro 2025.2.1 | Windows 11 Home 24H2
carlosrealyv
Observer
Observer
Figured it out, thank you all.
kacper.suchomski
This segment (eccentric cone) can be added again using Loft flange. The model created in this way can be flattened.
Kacper Suchomski
s_ciocca
Ciao,
un altro metodo è quello di creare una "lamiera tramoggia" (per imbutitura oppure per pressa piegatrice) ed applicare un taglio di separazione.
In questo modo puoi spianare senza nessun problema la tua lamiera.
Vedi esempi
Stefano
carlosrealyv
Observer
Observer
Grazie mille!
