Gear Generator for CNC Machining
caleb_aragon
caleb_aragon
Community Visitor
Community Visitor
I am in search of more information regarding the precision of the gear generator and extract tooth profile options provided in Inventor 2026. I have read the gear generator uses Wellman's Odontograph simplified method and isn't good enough for machining or use in a transmission. Is there any way I can use Fusion360 to get a more precise gear for CNC machining.
swalton
Export the tooth form as a dxf? from the gear generator, then import it back to the part to cut the actual profile.
https://www.youtube.com/watch?v=1NxOhoS9pWM
Some interesting ideas for bevel gears here:
https://brianzawesomeblog.blogspot.com/2016/01/creating-involute-bevel-gears-in.html
There is a thread that was purged last year that might help.  I've filed an error report to the mods. It might be restored.  Try the wayback machine?
https://forums.autodesk.com/t5/inventor-forum/design-accelerator-spur-gears/td-p/4605217
Steve Walton
Inventor 2025
Vault Professional 2025
rosie_lucas1
Hi @caleb_aragon,
I just wanted to follow up and see if the suggestion shared by @swalton was helpful and addressed your question.
If everything is resolved, would you mind clicking the “Accept Solution” button on the response that helped you most? It makes it easier for others in the community to find useful answers in the future.
If you’re still working through the issue, feel free to share an update here—everyone will be happy to continue helping and suggest next steps.
Thanks, and I look forward to hearing from you!
Best regards,
Rosie | Community Manager
