Fuzzy Color
Fuzzy Color
Jose_Merino
Fuzzy Color
Jose_Merino
I'm making a structure but I want it to be white, but when i put white or snow in my appearance window, i keep seeing it gray (image below) how can I make it real white?
Thank You.
I have another question, before in this forum I have the bottom to insert an image and now I have not? why?
ToddPig
Great question.
I tried changing the RGB values to white [ 255, 255 ,255 ], and It still looked grey.
Inventor 2018
(23+ years of Solidworks, 5+ years of fighting Inventor)
Autodesk Vault Pro 2018
iParts = iHeadache
mdavis22569
you'd see more of the white when you render it ...
1st picture just your normal Assembly
2nd ..rendered
how you can play with your light options under view
it defaults to Two Lights
Try Cool lights
You go into the settings at the bottom of the light options
@ToddPig this would answer be the area you want to adjust when you were asking Blair.
Mike Davis
cad
Try this:
Daniel248
I would advise against 'artificially' brightening a colour by using self-illumination settings: one day you'll want to get a good rendering of that model, and then you'll find out why.
The brightness of a white (RGB 255,255,255) finish depends on many settings (lights, position of lights relative to the surface observed, surface properties - glossiness, reflectivity, texture, etc.). In the screenshot below I've simply used 'White Porcelain' with colour set at RGB 255,255,255 and 'Grey Room' environment. It's white enough for me:
