Inventor Forum
FRP - Fiberglass Reinforced Plastic
8 REPLIES 8
Message 1 of 9
8663 Views, 8 Replies
Anyone know if FRP is available in Autodesk Inventor's material library? I don't see it there but maybe it falls under a different name. If it's not in the library is there any way to add new material?
Jordan
8 REPLIES 8
Message 2 of 9
JDMather
Go to the Material Browser to add a New Material.
Message 3 of 9
in reply to: JDMather
Thanks JD. This is good to know for future reference but I actually found the material in the library after all.
Message 4 of 9
Would you be able to share where you found the FRP materials in Inventor?  Is this just the material or also the shapes in Content Center?
Message 5 of 9
Hello, It's been a while since I used inventor so my apologies if this is not clear. In the above post I mentioned how I found FRP. This is not entirely correct as I found GFRP and another varient. I found these in the Autodesk and Inventor Material Libraries. What I did was find the material properties of the FRP I needed for my part and followed JD's instructions on how to create a new material. See image 2 and follow instructions above. I hope this helps.
Message 6 of 9
FRP properties attached. You should verify these with another source.
Message 7 of 9
Apologies but my attachment will not take.
Message 8 of 9
Thanks for trying.
Message 9 of 9
