Inventor Forum
From ipt to dxf?
12 REPLIES 12
Message 1 of 13
MP07
18122 Views, 12 Replies
From ipt to dxf?
First of all hello everyone Smiley Wink
I'm new to inventor, used it to design a computer case of my own, so now that I got all of my parts in ipt I need to convert them to dxf in 1:1 scale.
What is the easiest way to do that? I found some info here http://forums.autodesk.com/t5/Autodesk-Inventor/Convert-an-ipt-drawing-to-a-dwg-or-dxf-using-Invento... but in the Environments tab I don't have any ''AEC Exchange''.
Oh and another thing, after sketching all my parts I ''deleted'' the dimensions from the view, so is there any way I can make them show up in that dxf because I will have to send the dxf's to someone who will laser cut the parts, so dimensions have to be shown of course, or do I have to add them one by one?
Thank You Smiley Happy
12 REPLIES 12
Message 2 of 13
KevinLi-Autodesk
in reply to: MP07
If you use Inventor2011, please go to Environments tab, click Add-Ins button to invoke Add-In manager dialog box, then check if AEC Exchange is loaded or not, see attached image.
You can create a inventor drawing file then create views for your part, add dimensions, then you can save copy as it with DXF file format.
Hope it helps a bit.
Kevin Li
Kevin-Hongyuan Li
Software Quality Assurance Engineer
Design, Lifecycle and Simulation Product Group
Direct: +86 21 2039 6025
Email: Hongyuan.Li@autodesk.com
Autodesk, Inc.
NO. 130, Lane 91, E Shan Rd
Building 12, Floor 6,
Shanghai 200127, PRC
www.autodesk.com
Message 3 of 13
MP07
in reply to: KevinLi-Autodesk
Hi Kevin,
thank You for your response, well it seems I'm missing some add-ins stuff (check attachment) and that add-on is missing
Well I guess there's no other way but create a drawing, put the views I want and then extract it to dxf right?
Message 4 of 13
KevinLi-Autodesk
in reply to: MP07
Hi MP07,
Yes.
Kevin Li
Kevin-Hongyuan Li
Autodesk, Inc.
www.autodesk.com
Message 5 of 13
guido_66
If you made ipt with the intention of having them lasercut, you can simply right click on the face of the ipt and select export face as..
This will produce a 1:1 scale dxf with only the face contours in it. DXF's for laser cutting should have no more information or dimensions in them, only the contour.
Message 6 of 13
JDMather
in reply to: MP07
You should fix your install so the AEC Exchange is loaded.
The CADWhisperer YouTube Channel
Message 7 of 13
MP07
in reply to: JDMather
@guido
omg thx works like a charm Smiley Wink
@JdMather
thx I'll do that so I can try that way as well, btw by ''fix your install'' you mean I should try running the setup again and then it gives me some option to ''repair'' or similar or a complete reinstall? I suppose the first option?
Mauro
Message 8 of 13
JDMather
in reply to: MP07
I don't know what you did that the Add-ins isn't fully populated.
Did you have anti-virus and UAC turned off during install?
I would first try a Repair Install (right click in Control Panel).
Don't try anything drastic (like uninstall) untill all other options exhausted.
If you do end up uninstall/reinstall search Google for Autodesk Clean Uninstall instructions.
Message 9 of 13
MP07
Yes it's strange, I don't remember selecting/choosing which options/add-ons to install or not.anyway I'll try it right now and edit this message afterwards
Oh btw my antivirus software(avira security suite) wasn't turned off(didn't know it's advisable to turn it off during install) and my UAC is always turned off
Message 10 of 13
rdyson
AEC is not available on either of my installs of 2012 Premium.
Is it on your 2012 Ultimate, JD?
PDSU 2016
Message 11 of 13
MP07
in reply to: rdyson
Sorry I do remember a selection during install, saw it now, installed all the missing stuff but still not present afterwards
Message 12 of 13
patrick.miller
in reply to: rdyson
Looking at your screen capture, you are using 2012. AEC Exchange was renamed to BIM Exchange in 2012 and it is listed in your add-ins and the Environments tab.
Patrick Miller
User Experience Designer
Fusion 360 Learning
Message 13 of 13
TattooJoe
in reply to: guido_66
Reading your post just saved me a boatload of time, thanks for the good advice.
Joe
Joe F.
Project Engineer
Traffic and Parking Control Company
