Framework Orientation change
lkirit2000
Advisor Advisor
lkirit2000
Hi
I created a frame using framework. The next day I found that profile orientations are rotated by 180 degrees How this Happened? How to prevent this in future ?
It causes delays and rework?
Has anyone come across this situation in the past?
Kiri
SBix26
Do you mean Frame Generator?  What version of Inventor?
Sam B
Inventor Pro 2024.2 | Windows 11 Home 22H2
johnsonshiue
Hi! Edit the misaligned member -> click on Align button -> select a stable planar reference.
Many thanks!
Software Test Engineer
kiri.loganathan6E3YL
Hi SBix26.
Yes, it is in Frame work. Inventor 2024.
Hi Johnson,
Where are these options, align button, and planner reference?
kacper.suchomski
On the dialog box of FG (create or edit).
Kacper Suchomski
