Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Frame Generator!!!!
jyothissurendran
Frame Generator!!!!
jyothissurendran
I am using Frame generator to create a structure by selecting placement option as " Insert members on Edges". But in the browser i found that so many *.ipt parts are created according to the profiles edges which one i selected ( made of arcs and lines). So i tried another option, at the time of selecting the profile for frame generator (using insert member on edges) i use "chain select in place of multy select".  But again am not able to get the result as  single part (like in sweep). Any option available to create in such a way that, if i  select  a chain made up of lines and arcs does it able to generate a single part by frame generator ? Any one can help me on this ?
Jyothis Surendran
Autodesk Autocad 2014 & Inventor Professional Suite 2010
Windows 10
brendan.henderson
If I am understanding you correctly the problem is the generation of many part files but you want them 'merged.? Use the Merge option. See graphic below.
This then make 1 IPT file. See the grahic below.
Brendan Henderson
CAD Manager
New Blog | Old Blog | Google+ | Twitter
Inventor 2016 PDSU Build 236, Release 2016.2.2, Vault Professional 2016 Update 1, Win 7 64 bit
Please use "Accept as Solution" & give "Kudos" if this response helped you.
jyothissurendran
Thanks Brendan Henderson for the kind support...
Jyothis Surendran
Windows 10
