Frame Generator
Frame Generator
kevin6257
Frame Generator
kevin6257
Hi. I have made a frame of "I" beams and run pipe through the sides. I can't work out how to remove the "I" beam from the inside of the pipe at the intersection. Can you please help.
TheCADWhisperer
@kevin6257
Depends on how you did it.
One solution might be to open the part file and select the Delete Face command.  Set the option to Lump or Void and then select your leftover lump.
Attach your assembly here if you can’t figure it out.
dimamazutaMMJ32
Hi @kevin6257!
Is this what you need?
kevin6257
Hi. Thankyou for your input. Very much appreciated
kevin6257
Yes very good. The video made it easy. Thankyou
