Hi All,
I have been playing with this blog post to round the G_L parameter using custom property format and incorporate it in the part number for frame generator components. http://blog.ads-sol.com/2014/04/frame-generator-and-content-center.html
This works very well - however as discussed by ADS it does not persevere when the frame member is replaced by another section (with the same edit). You can change the size but not the section... You must delete the member and insert again which is not ideal for parts with bolt holes etc...
The reason I am interested in this is I sometimes have members that are so close they round to the same length but still display as separate entities on the parts list (due to subtle platform falls, bracing etc...). These then need to be edited to be resolved into the same entry. Have any of you found work-arounds for this (that don't involve manual BOM manipulation)?
Cheers,
Glenn
