Frame generator problem miter
RadoG
Message 1 of 12
RadoG
Frame generator problem miter see picture. This command not work correctly I want these edges to be aligned.
Replies (11)
Message 2 of 12
mdavis22569
Can you share the files?
Update(s) installed?
What happens if you try this:
Mike Davis
Message 3 of 12
JDMather
It doesn’t look like the frame members were placed properly before
Message 4 of 12
RadoG
I want these edges to be aligned. I will  cut free  edge. I want result from picture command.
Message 5 of 12
JDMather
Like this (see Attached)?
Message 6 of 12
RadoG
I want this result from this command. how to make ?
Message 7 of 12
JDMather
Inventor isn't going to change the position on you.
You must enter the 10mm Offset...
Message 8 of 12
RadoG
This is not decision . How work command  offset direction in miter. Why result is equal and only change picture command.
Message 9 of 12
JDMather
Wrong tool, not offset in Miter - that controls gap.
You need to Offset in placement.
Message 10 of 12
JDMather
Ping @johnsonshiue
You might want to take a look at this one.
Yesterday I did not properly exercise this as I did not have DIN standard.
Today I reproduced with ISO standard and got unexpected results when I used Miter.
So then I use an assembly level cut to get what I think was the OP's design intent.
Message 11 of 12
3D4Play
IFF the miter angle does not matter, then use the full miter cut option:
Message 12 of 12
johnsonshiue
Hi Guys,
The behavior does look inconsistent. I cannot explain it either. It looks like a bug to me. Let me work with the project team to understand it better.
Many thanks!
Software Test Engineer
