Frame Generator parts move freely inside assembly when adaptative
Inventor 2019
I created a frame generator structure in assembly1. I placed assembly1 inside assembly2 and completely mated it. While inside assembly2, I edited a part of my assembly1 frame generators structure and projected two holes from another part inside assembly2. After projecting the holes, assembly1 became adaptative. At that point, I can, for whatever reason, click and drag a part of my frame while inside assembly2 and the entire thing breaks and moves around freely. Parts seems to be half mated together and somehow moves together. When I open assembly1, all the parts are missplaced the way they were while inside assembly2, but I can't move them at all, as if the frame is fully mated like it should be. There are no update icon available (yellow lightning) and Rebuild All doesn't do a single thing.
At that point I can Undo until it is back together. I had to remove adaptativity for the frame inside assembly1 to stop moving if I dragged it around.
Anyone know what is causing this faulty behavior? My understanding is that everything should be fixed.... just like any other sub-assembly when you make them adaptative.
