Frame Generator not updating with sketch
joshua.wolffQPNF7
Observer Observer
joshua.wolffQPNF7
Observer
Observer
I have a sketch that is driving my frame. When I change the sketch the frame does not update.
I am using Inventor 2022.  This problem has only started in the last 12 hours.  I have just updated to the latest version of Inventor but the problem is still reoccuring.  Re-build is not working and my assembly does not contain any view reps or additional model states and the reference sketch is not grounded.
Can someone please assist?
johnsonshiue
Hi Joshua,
I vaguely remember we had a bug in 2022 like that but it got resolved in later updates. Please install 2022.4 update and the 2022.4.3 update.
Many thanks!
Software Test Engineer
joshua.wolffQPNF7
Observer
Observer
Hi Johnson,
Thanks for the response, but updates have been installed and have not solved the problem....
Started experiencing the problem within the last 12 hours
CCarreiras
You did do the assembly in a previous Inventor version?
Make sure all files are migrated to the new Inventor version.
Use TaskManager to migrate all files in the project folder to the new inventor version.
CCarreiras
johnsonshiue
Hi Joshua,
I will need to see the files. If possible, please share the files in zip here or send it to me directly johnson.shiue@autodesk.com. I would like to understand the unassociative frame behavior.
Many thanks!
