Frame generator miter joint (combined cut)
Message 1 of 9
I have two different sections meeting at the sloping corner at 122 deg horizontally and about 7 deg vertically ("profile1.png" and "profile2.png) as shown in picture "generated frame.png". To join those to sections correctly I need to apply what is called a combined-cut (attached a hand sketch "CombinedCut.png") what is basically a miter joint turned at an angle ( splayed miter joint).
I'm using frame generator for this task and miter function produces an incorrect result (shown in picture "Capture1.png").
Is there a way to make this kind of joint (I'm using Inventor 2018) using frame generator ?
If not - what is the best way make this joint?
Replies (8)
Message 2 of 9
blair
To use Frame Gen, the profiles need to be Authoring as a custom profile within the Fram-Gen program. I've attached a file how to publish components to CC for use with Frame Gen.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 3 of 9
Blair,
Thanks a lot for the attachment, but that is not exectly what I'm after. I was asking whether it's possible to make a miter joint on two planes. Unless I missed that part where I have to enter a value in that property table to force miter at an angle.
Message 4 of 9
salariua
hi @Anonymous,
I don't have access to 2018 for a couple of hours but you will get better results if you attach a Pack and Go of the assembly containing the skeleton and frame generator assembly.
Remove everything else from it (or create a new test assembly for us) and use File / Save As / Pack and Go and share the zip with us, please.
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
Message 5 of 9
Hi, @salariua
I created a new, clean setup, that replicates a scenario I'm struggling to deal with. hopefully there is a way to accomplish this joint without manually editing and constraining every single time...
Thank you for your help
Message 6 of 9
Using this opportunity I would like to raise another question retarding this particular assembly.
You might notice that GU sub assemblies used as a path for Frame generator are not fully constrained together. Both of them are grounded. I was unable to figure out how can I properly constrain them so I added a rotational joint, than deleted it moved them apart and grounded. That is close but not correct.
What constrains should I apply in this kind of situation to achieve a desirable and correct result result?
Message 7 of 9
blair
The items within the Frame-Gen as positioned and controlled by the controlling Sketch file and the Frame-Gen control window. I've never used a separate work-plane to trim/mitre an Frame-Gen member. You can try by placing a Work Plane at your desired angle and location and use it as your Trim/Mitre surface rather than another Frame-Gen member.
This is why you see only grounded items within the Frame-Gen and no constraints.
Delta Tau Chi ΔΤΧ
Message 8 of 9
@blair,
Unfortunately Frame generators miter command wont allow to select a work plane instead of second frame member, so that does not work.
I found a work around creating a shrink wrap and then sculpting solids around a work plane.
It would be great tho if frame generators Miter function could do a mater at a different angle other than 45deg. just by imputing an angle.
Message 9 of 9
blair
You can add your request to the "Ideas" FORUM. The link is at the top, click on "Ideas" on this web-page.
Delta Tau Chi ΔΤΧ
