Frame generator : End treatment
chachaman
chachaman
Why is it that if you construct a frame based on a skeleton, and then add end treatments to the frame members (miters, notches , etc...), and then afterwards edit the geometry of the skeleton....the frame won't update ? ( seems to want you to remove the end treatments for the frame to update to the new skeleton geometry )
Is this the way it was intended to function ^
Thx
_Cha
Probably was major discussion of retaining adaptability on the end
treatments. It was probably dropped to speed up system performance and
stability. Much the same as adaptively in the normal environment.
Dell 670 dual Xeon - 3.2
3gb memory, SCSI320-15k
XP-Pro, sp2
Quadro FX3400: Driver: 169.21 Direct3D
IV2008-pro sp2,
SpacePilot Rel V: 3.5.4 Dvr V: 6.4.4 Firmware 3.12
wrote in message news:5842964@discussion.autodesk.com...
Thx
_Cha
