Frame Generator – Display Member Lengths Without Decimals, Trailing Zeros, or "mm" (Batch Update)
aravind_koder
aravind_koder
Hi all,
I'm looking to update the Frame Generator member naming convention so that the length values appear without decimal places, trailing zeros, or the "mm" unit suffix. I know this can be manually done at the part level, but with large assemblies, doing it one member at a time is not practical.
Is there a way to apply this formatting globally or in batch, either via styles, templates, or automation (iLogic, for example)? If there is a previous discussion post or tutorial video covering this, I’d really appreciate a link or pointer.
The same goes for the description, size, and material fields—I’d like to standardize the format across all members without having to update each one manually.
johnsonshiue
Hi! I could be wrong but I thought this could be done within the PartsList. Edit the PartsList and right-click on the column -> Format Column. You should be able to change the precision.
If it does not work, please share the files in zip here. The forum experts can help take a closer look.
Many thanks!
Software Test Engineer
aravind_koder
@johnsonshiue
I tried fixing it thru by editing the partlist, but it's not working.
I will share the file thru zip.
Aravind
